6mm beads for mono
Beenereb4
We are down to redo a mono job we done last year! The job was fine until the client decided they wanted to change the windows and consequently the fitters have wrecked the job.
Money isn't an issue and they insist on mono again, not patch and paint or thincoat over the top.
Will 6mm beads dabbed on be enough to not get any problems?
is it just the reveals or the face that is damaged?
if its the reveals i would grind the render off and redo. leaving the original beads
No love by the fitters Dan, they don't want bands either.
I wouldn't even consider 6mm beads for mono they are for thin coat renders at that thickness you could end up scratching right back to the original coat nearly as Dan says best option you have to lay down the law to them really your the renderer
If you're going over the too of mono I don't think it's a problem if it's same colour, Krend told us we can put 6mm beads over a section that had baked in the sun once and just re scratch it using 6mm
