Any tips on avoiding lumps while mixing joint compound
mm27760
Tried this clean buck et clean tools.
Sometimes it mixes ok other times if forms lumps
tried powder first and water first
using stirrer on a battery drill
always add the powder to the water... I also get the water spinning before I pour the gear in... scrape round the edges when mixing with a bucket trowel...
The stirrer on a battery drill probably is not man enough for the job... you can pick up cheap mixers that will be cheaper than replacing your drill :D
You get lumps when you add too much powder to the water then have to thin it down with more water, that's only way unless you have a bad bag. I can mix it to a lump free consistency using a scraper in a bucket so it's not hard
When you say jointing compound is that joint filler or joint cement. If it's joint cement it's best to mix then leave for a good while then mix again
Just f**k**g eat it pretending it's school semolina (only works if your over 40 years old)
Bit technical this :tonto:
Put water in bucket and add powder mix until lump free voila!
For small amounts just use a scraper to mix.
Simple really.
I'm sure there's a boom for this.
If I were a techno geek I'd make an app, giving instructions on how,to mix stuff up.......(.@ Danny )
Then one day Rodney I'll be a millionaire........
