1. Want to see how the new TPF works? Click here or you can drop me an email danny@plasterersforum.com
    Dismiss Notice
  2. The Plasterers Forum has now made it even easier to share photos and videos than ever before Click Here To Learn How
    Dismiss Notice
  3. TPF is the biggest plastering community and resource on internet... we are still growing.... we are nearly 10 years old so we are here for a long time yet...
    Dismiss Notice
  4. The Plasterers Forum is growing but we need your help to keep it growing.... Introduce yourself and say hello get involved... they dont bite :-)
    Dismiss Notice
  5. The Plasterers Forum is very busy!! ...25% up on last year!! Be a part of the biggest plastering community
    Dismiss Notice
  6. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
    Dismiss Notice
Ewi novice
Discussion in 'The Plasterers Forums FAQ's' started by johniosaif, Sep 22, 2017.
  1. johniosaif
    johniosaif Private Member
    i have a small Ewi job that i want to do, it's over ply, the only info I have so far is,the foreman thinks it's 100 mm insulation, it's about 9 linear metres and 2.1 high ,it's on a flat first floor roof , I've only done one Ewi job before on my own shed, it turned out alright , but I'd take great care on this one , what's the abc to fixing it to ply ,I take it that it needs fixing to the studs mechanically and not dabbed like I did on to the block work ,?
    Second part is the external walls of the swimming pool needs rendering,most of its block but a third of it is insulation,so block meeting insulation at two sections, no spec on it ,just to be rendered I'm advised , again I haven't ewi'd over render yet but it must be easy enough,the main concern is to do it in a way that creates one even finish that's uniform and neat , it's only about 400mm deep and 26 linear meter , just something different to do and learn in the process . Any advice appreciated
  2. vfr12
    vfr12 Private Member
    1- yes , screw them to the studs and to the ply as well
    2- fix battens to the edge, both sides of the block work, or mf angles and fix ply or render board. I would put tyvek over the ply before fixing the boards
  3. madmonk
    madmonk Private Member
    what system ya using pal
  4. zolco
    zolco Private Member
    Can you not put an expansion bead where the two substrate meets on the swimming pool?
  5. johniosaif
    Probably Weber
  6. johniosaif
    All options are open
  7. madmonk
    Is the block work flush with the insulation you could just mesh it or where it meets put a strip of mesh over first say 300mm then mesh the lot again
    • Like Like x 2
  8. madmonk
    so I take it your using weber lac?
    • Like Like x 1
  9. johniosaif
    There's a kick about 15 mm
  10. johniosaif
    Yes, that's the plan,
  11. johniosaif
    Just wondering how the insulation is normally fixed to ply
  12. madmonk
    screwed on mate
  13. smedhead
    smedhead Active Member
    Big mushrooms:maraca:
    • Like Like x 1
  14. madmonk
    I just buy the plastic washers then screw through
    • Like Like x 1
  15. johniosaif
    When you apply Weber thin coat over sand / cement is it the same process ,lac ,mesh, top,coat ?
  16. Marshy
    Marshy Private Member
    Get a rep out to spec it then you are covered. Plus post pics of milf custonerz /next doors etc
    • Like Like x 2
    • Agree Agree x 1
    • Funny Funny x 1
  17. madmonk
    I would prime it first with pr310 it shouldn't need mesh really but you can put it in for what it costs
    • Like Like x 1
Share This Page
