1. Want to see how the new TPF works? Click here or you can drop me an email danny@plasterersforum.com
    Dismiss Notice
  2. The Plasterers Forum has now made it even easier to share photos and videos than ever before Click Here To Learn How
    Dismiss Notice
  3. TPF is the biggest plastering community and resource on internet... we are still growing.... we are nearly 10 years old so we are here for a long time yet...
    Dismiss Notice
  4. The Plasterers Forum is growing but we need your help to keep it growing.... Introduce yourself and say hello get involved... they dont bite :-)
    Dismiss Notice
  5. The Plasterers Forum is very busy!! ...25% up on last year!! Be a part of the biggest plastering community
    Dismiss Notice
  6. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
    Dismiss Notice
First time DIY'er looking to get some muck on my walls.
Discussion in 'New To Plastering? Read This First...' started by grounzero, Aug 1, 2017.
  1. Nicm
    Nicm Well-Known Member
    A pro will tell you leave him alone till he's finished.And have his money ready.
    • Like Like x 1
    • Agree Agree x 1
  2. Optimum
    Optimum Member
    Ok then pick the wall ur gonna do and get the Chase's bonded and flat then pregrit the wall just do the one wall mate u need to leave the pregrit 24 hours after u put it on before plastering then get everything ready send me a pic when it's pregrited and your all ready to start don't spend loads on the best trowels just get a hawk and trowel ur comfy with for now size of trowel etc and get a plastering sponge float it might just be the thing that saves u and a water spray bottle. If your gonna do this then I will give u all the help I can
  3. Dropsalot
    Dropsalot Private Member
    Remember.....always face the wall you're plastering.
    Always start from the left or the right......
    Never plaster on a Tuesday......
    Learn to whistle.....(it's a useful skill)...
    Never push when you should be pulling.....and vice versa....
    A journey of a thousand miles starts with a single malt......maybe...(y)
  4. bopper
    bopper Active Member
    And we will all be here to cheer you on every step of the way......won't we men.
    • Funny Funny x 1
  5. grounzero
    grounzero New Member
    True, this week I looked after some work experience kids in my day job (software engineer) and actual output has been zero
    • Like Like x 1
  6. grounzero
    Ok lads, I managed to get as far as blue gritting over the weekend, It seemed to run down the walls quite a bit so caked it on like a whores makeup.
    A 10 litre tub wasn't enough to do the small room as the wall you can't see in the picture isn't yet done and I need to fill in some gaps on the ceiling. I might get an extended roller for that as holding my arm above my head for long periods was pretty tough.
    Am I doing ok so far?
  7. aufweder
    aufweder Member
    Mate it's gonna cost you a fortune in blue grit one tub should do at least three rooms get a tub of pva and put some water in with both keep knocking it together so grit doesn't settle on the bottom, I can't tell you ratios as we've been doing it that long I just mix it together until happy but key is keeping it mixed
  8. aufweder
    aufweder Member
    Or get a fu......king plasterer
  9. grounzero
    Is there any danger of applying too much blue grit? Am thinking if it gets too much and I need to get a pro in having all the walls pre-gritted would allow them to do the job much faster?
  10. moy83
    moy83 Active Member
    No danger , in fact I think having the place blue gritted before getting a price makes it look alot easier for the plasterer . Just have it well done and get it well into dry looking cracks and board edges
    • Like Like x 1
  11. Optimum
    Optimum Member
    Well done mate looks good but go to the floor and get it in the corners
    • Agree Agree x 1
  12. Optimum
    Optimum Member
    When you thinking of skimming the wall?
  13. Danny
    Danny TPF OWNER
    that is some coverage.... :D it all needs to be blue though :D dont miss anywhere.
    • Like Like x 1
  14. grounzero
    Possibly Wednesday if I can I get time off work. I only had a roller so will use a brush to get to the corners. Would liked to have done more over weekend but got stuck on other jobs around the house. I've got one bag of bonding plaster and 1 multi finish. The tiler who's doing my bathroom at the moment has caked my trowels in cement. They were only cheap ones from Robert Dyas but annoying nevertheless. If it doesn't go too well I'll consider getting someone in and hope the prep work I've done gets considered in the quote. I'd regret not giving it a go before though.
  15. Danny
    Danny TPF OWNER
    fair play have a go and and see what it looks like :D If it looks ok great :D If it looks pants then get someone in :D
    • Like Like x 1
  16. stuart23
    stuart23 Private Member
    Should have pva'd it and saved yourself some money.
    • Agree Agree x 1
  17. grounzero
    I did consider this, after some fairly deep reading up I found plaster is best be applied while the pva is still tacky, though reading some of the threads on here would suggest otherwise. Seemed that a lot of spreads are put off by blue grit as they don't want to wait around for it it to dry whereas I've got time to allow for drying and managed to get a reasonable price so thought gritting would be the 'sexier' option when it came to prep work.
  18. stuart23
    Replace 'sexier' with 'expensive' lol
    It's up to you mate, not as if your doing anything wrong. I've just never bought into the grit stuff, in 12 years of plastering I've used it twice.
  19. Optimum
    Optimum Member
    Stick with the grit if you've not plastered before it will be easier with the timing ,will give u more time to get across the wall and get a clean trowel for it don't use a dirty trowel good clean one and keep it clean
    • Agree Agree x 1
  20. Optimum
    Optimum Member
    You've gone quiet grounzero ? Have u f**k*d it up?
  21. grounzero
    Hey, been busy with the day job. I tooled up and bought a marshaltown 11 inch beginners trowel (the stainless steel gold one) and a 14 inch s*p*r*lex. Got a good price but that meant waiting for delivery.
    At the moment I'm still on the prep as I want to get it as good as I can. Yesterday I removed an internal window opening that was originally there to let light into the stairs and blocked it up with engineering bricks (pic attached). I could have studded it but thought this would add better soundproofing.
    Should I grit the bricks as well? Would need layering up as the opening is about 2cm back from the original lime plaster. It seems pretty solid but not sure whether I should have toothed it in at the sides rather than chop the end ones? To get the top row I either need to chop a couple of bricks length ways or remove the ceiling laths and bang the top row into place from the loft as it took quite a bit of mortar.
  22. Optimum
    Optimum Member
    Don't grit the bricks mate
  23. Optimum
    Optimum Member
    I think if you've set them back enough you could plasterboard over them if not get some bonding over them nice and flat then u could grit the bonding once it's dry
    • Like Like x 1
Share This Page
