See I disagree with this, we just wet it down before coving. Pva no matter how weak can be seen after painting imo. I know plenty do it that way just don't understand it.we cove same day.
if you cove later give the area where the fits on ceiling and wall a weak coat of pva, this prevents the adhesive from drying to quick.
We just soak enough to cover the length going up then stick it straight away, never had any problems but each to there own mate.we pva as we find it easy to clean down the excess adhesive. if the adhesive dries to quickly it goes to crumble and does not reach full strength.
But a bag of ca120 and no need to PVA, can be done straight after I also cove first then skim to it sometimes.
You need a bit of suction to get a nice clean finish on the wall and ceiling linesSee I disagree with this, we just wet it down before coving. Pva no matter how weak can be seen after painting imo. I know plenty do it that way just don't understand it.
same day I stick it with drywall adhesive
Same here
thats cos we are pros DId you get my PM?
Just seen it now, sending reply now
Is there a TPF inner-circle??
Why what?Why
Why what?
Main reason you don't have to wait for the ceiling to go off and your away after final trowel.Why would you put the coving up first then skim it ?
Cove adhesive to stick then finish off with easyfill. It dose say in the spec you can uses easyfill to stick though. Can take a week to dry out which causes problems if painting to soon.. Cove adhesive being the slowest drying product i have ever used. Really takes days / weeksA builder I used to work for would always get me in to cove right after skimming. Time after time, the damp transferred to the cove and it went yellow on painting. I now only use Easifill to stick cove up with, and always pop a couple of sheradised pins in each length (belt & braces). Easifill cleans off lovely, even on bone dry plaster.
Only the circle of trustIs there a TPF inner-circle??
Just do half and halfHmmm, conflicting advice now
Skim and cove or leave to dry?!
G**Just seen it now, sending reply now
Same as the bg cove adhesive is shite!I’ve had BG Cove Adhesive fail numerous times so no longer use it. Drywall adhesive sticks like s**t to a blanket but some brands can be gritty. Easifill does retain moisture for longer, as you say. If customers weren’t always in such a rush to finish, there wouldn’t be problems. Went past a site in Truro recently where the external walks on a block of three storey town houses were rendered one day and painted the next. A recipe for disaster.
