1. Want to see how the new TPF works? Click here or you can drop me an email danny@plasterersforum.com
    Dismiss Notice
  2. The Plasterers Forum has now made it even easier to share photos and videos than ever before Click Here To Learn How
    Dismiss Notice
  3. TPF is the biggest plastering community and resource on internet... we are still growing.... we are nearly 10 years old so we are here for a long time yet...
    Dismiss Notice
  4. The Plasterers Forum is growing but we need your help to keep it growing.... Introduce yourself and say hello get involved... they dont bite :-)
    Dismiss Notice
  5. The Plasterers Forum is very busy!! ...25% up on last year!! Be a part of the biggest plastering community
    Dismiss Notice
  6. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
    Dismiss Notice
How can I get more time out of multi
Discussion in 'Video Tutorials On How To Use The Plasterers Forum' started by mickyburr, Jun 28, 2017.
  1. mickyburr
    mickyburr New Member
    double pva a ceiling 20sq started laying on by the time I get to the end the start of it is going off help
  2. gps
    gps Private Member
    There is the product extratime not used it myself.
    Happens to us all at times, it just depends on the suction.
    The obvious though is to be a bit quicker, how long is it taking you to apply the 1st cost ?
  3. stuart23
    stuart23 Private Member
  4. zombie
    zombie Private Member
    Pack up plastering if you can't keep on top of a 20m2 lid!
    • Funny Funny x 3
    • Agree Agree x 2
  5. Stick Cream of Tartar baking powder in I just a sprinkle
  6. Danny
    Danny TPF OWNER
    Use extratime but I would look at your technique and see where you can streamline the operation :D
  7. Lodan
    Lodan Private Member
    Lay half on and drop back and flatten then other half.....but you should really be able to keep up with 20sqm unless its really high suction....if suction was the problem more PVA until you've killed it....what ratio you use for pva
    • Like Like x 2
  8. mickyburr
    How much do I put in per 25kilo bag and how much longer will I get icky
  9. mickyburr
    4to1
  10. Danny
    Danny TPF OWNER
    buy extratime (think it is £2 for sachet) that will give you the time you need... Then when you are use to it you can go and buy C of T if you like and work it out yourself
  11. zombie
    Tbh I never use PVA diluted any more than 50/50
    I know its stated 5/1 followed by 3/1
    But tbh 50/50 then leave to dry IMO holds off suction far more!
    • Agree Agree x 2
    • Like Like x 1
  12. Danny
    Danny TPF OWNER
    I dont know anybody that measures it out accurately!!
    • Agree Agree x 1
  13. Natwasere
    Natwasere Active Member
    Had a 20odd m2 a while back that was giving me the run around if you actually let the pva fully dry out and cure it holds it back much better then say same day.
    I do dilute it down 3-4:1 for things that are high suction but you do need to give it another coat of something stronger after. And tbh it's not like 1:1 has ever failed me
    • Agree Agree x 2
  14. Danny
    Danny TPF OWNER
    Thats pretty much how I do it anyway :D
  15. Cockney1
    Cockney1 Active Member
    That's far to weak mate!
  16. s61
    s61 Active Member
    I always put a weak coat of pva on first so it soaks in I find if I put a really strong mix of pva on it just lays on the top
    • Agree Agree x 2
  17. Natwasere
    Just like painting really .... first coat is normally watered down on sucky surfaces.
  18. choppa
    choppa Active Member
    Just looked at this stuff pack of 5 £15 is it worth that? Iv never used retarder for multi.
  19. choppa
    What was the background?
  20. andrwclem
    andrwclem Member
    Sounds like it is your background sucking up , as other peeps have said control your suction
    If it is plasterboard search for rolling set on plasterers forum
    Sent from my SM-G930F using Tapatalk
  21. Danny
    Danny TPF OWNER
    I would say it is... although if the background is sucking like a prozzy on price then I would rey and control that :D
    • Funny Funny x 1
  22. choppa
    Hmmm I may give this a bash.
  23. themucky1
    themucky1 Well-Known Member
    Tip the 5ltr tub of uni in a bucket then fill the empty uni tub with water and put that into the bucket with the uni in, there you have it a 50/50 mix and I'll give you that info for free
    • Agree Agree x 1
  24. stuart23
    Problem with 50/50 pva is some brands are like coloured water to start with. You should know yourself the consistency when you water it down by mixing it and you can change the mix ratio depending what your doing.
    • Agree Agree x 2
  25. zombie
    Tbf I think with PVA you should buy what you know and trust and stuck with it at the ratio you trust!
    Wickes own brand does me fine 1 tub @50/50 over any background leave to dry and bobs yer uncle!
    • Like Like x 1
    • Agree Agree x 1
  26. Danny
    Danny TPF OWNER
    Yeah exactly.... it needs as much as it needs :D
    • Agree Agree x 1
  27. scottie5
    scottie5 Private Member
    a big handful of pea shingle in the mix should slow the set down nicley.
    • Funny Funny x 3
Share This Page
