Job done
plaster man
Got the blocking out part done today time consuming
Would look nicer if the block work on the upper level ran into the quoins same as the lower level
With jobs like that you have to make the best compromise otherwise you would go mad customer loves it I was the second plasterer on this job frost one leged it after doing a bit of first coat when he seen what he had to do it was beyond his skill set
I'm impressed with what you have done ,
It’s all in the setting out.
No biggie it still looks good.
A bricklayer would see it straight off.
