marshall town sharpshooter 2
jacko001
hy fellas my question is .Ive just purchased a sharpshooter 2 from the states for fine texture finishes over smooth finish render , I cannot find anything about the compressor size I need to run the gun on.
went to machine mart and the arrogant t**t in there is trying to sell me a monster of a machine .
I don't mind paying 200 pound plus but 500 is taking the piss surely ..
any comments guys would be appreciated.
I've got one of there's with the 50 litre tank works fine [emoji1303]
this one
thanks mike that's good info mt.
what psi do you run it at mt.and does it stop and start if your working at height say gable end.
It's on about 6 bar and should be fine at high it should be ok with a hopper gun when your loading it it will give it time to build up air
another question mick. is the gun as good as they say. and what do you set it up for for orange peel as in the trigger pressure .have you got the sharpshooter 2.
cheers lee
I've got the Refina one you need about the 6 mm nozzle bit and go round in overlapping circles
Top tip don't do the front first try a bit out the way [emoji1303]
