Who uses one coat render or similar for going over old roughcast and is it any good ?
Davy sned Active Member Apr 29, 2017 #1 Who uses one coat render or similar for going over old roughcast and is it any good ?
Tomasz Member May 2, 2017 #3 If it is a stable substrate can use a K-rend Last edited by a moderator: May 2, 2017
JRW Rendering New Member May 3, 2017 #4 You can, as long as you remove as much paint as possible and use a base coat. I use SAS Products, Quick delivery
