Wonder how much mixed multi is thrown away because it's cheap
What's the process for finishing? Would it be treated the same as multi? Timings? I'd say multi with pva would be at most 70p - 80p m2We might be able to cut the price a bit with full loads deliveries and larger scale economy....also how much is multi per sqm real cost? My view the price is reasonable for older buildings breathable skim or complex shapes, etc while it is a bit expensive for plasterboard and more typical applications, even at £1.13 per sqm; so we'll see what we can do with the price..
Sent from my SM-G930F using Tapatalk
Sponge and trowel up...That's one of the application reviews, I believe another review was posted above by @bopper another one is imminent from @Plasterers1StopShop:
1st Trial of Vimark Plastex GB1
lime breathable finish. No need to PVA!
Trialled today on box room reskim. Over 100+ year old bare lime finish plaster, had been stripped of wallpaper & 1 wall with Drywall Adhesive and bare multi finish around reveals.
Didn't wet backgrounds or PVA, just went straight on.
Like nothing I've used before. Best I can describe is
Its like skimming with Gyproc EasyFill & wet drywall adhesive.
A bit sticky and stretchy but covers well and sticks like s**t to a blanket.
Trowels up and finishes just like Knauf MP75.
Smooth Matt Finish.
Only mixing and H&S instructions on the bag so Having not seen or read application instructions I winged it & treated it like any gypsum finish. I would have threw the whole room on in 1 but was unsure how it'd go with experimenting with a new material. 1st gauge blebbed a bit but later trowelled out.
Second gauge I found best and easiest way is rough on, Speedskim - you've got plenty of time b4 second coat and surprisingly it doesn't pull in dead quick even without PVA and on old dry substrates. Lay down 2nd coat - Speedskim - let it pull in & light sponge and trowel up.
Jobs a goodun, get paid and get home.
Will use again, would recommend & I'd now have no hesitation throwing loads on and dropping back to Speedskim as I go.
Much better than Uni Finish in my opinion. Will trial it on Plasterboard, Artex, Lime backing coat and Gypsum floating coats soon & see how that goes.
Seems a lot like the stuff we see George Kidd & others using in Australia.
Not really targetting top end when anyone without skill can bosh it on and just use a sponge!
Nice job @theclemoSo they should make it harder to finish?? Not a thing wrong with a sponge in the right hands or trowel. This is one coat and sponge was used.
Mixed feelings really.So they should make it harder to finish?? Not a thing wrong with a sponge in the right hands or trowel. This is one coat and sponge was used.
We all like easy street but any old idiot will be stealing your work the easier it gets!
Looks great that boss.Same for all trades. Just need to get ahead of the game. We do a lot of sand and cement on external over here. So I bought a machine and use ocr. No scud or scratch the scaffolding can come down 2 weeks quicker. I can get ocr to dry out consistent colour . As that's hard to do with sand and cement as sand is now f**k*d over here. I can make good money using ocr can do 100m2 a day at xm2
Ocr dry out
.View attachment 17883
Ive yet to try it through the machine. Is it as easy as s&c to rub up?
YesI have cement bands to do, could I use ocr and finish them in a day?
Very small stock of Plastestex GB1, about 70 bags is available with the next day delivery. Also much larger stock will be available shortly @Plasterers1StopShop. Ryan, how is the project at your home is going, any chance you could shoot a nice Plastex Gb1 application video mate? Thanks a lot
The key benefits of Plastex GB1 are high breathability or vapour permeability and high adhesion power which makes it an ideal material for internal renovation of older buildings. More on Plasteg GB1 at: http://www.vimark.com/en/prodotti/smooth-finish-coating-plaster-plastex-gb1/
You do know multi finish is 4 quid a bag?Plastex GB1 works out about 1.13 sqm/£ or £11 per bag with 12.5 sqm@2mm application thickness
@Plasterers1StopShop is it in stock yet ?
@Bauwer this looks very fine just like airless plaster. Can this stuff go through an airless machine?
I'm happy to test it [emoji106]
It is expensive sending the samples on it's own, but we could always add a bag or two on the top of your Bauwer or Vimark material order.
Unfortunately the job I spoke has been completed, will take a sample bag when I place a rasolite order this week.@Vincey @Beenereb4 @PlasterCraftDundee we have a small stock of Plastex GB1 now in the UK, about 70 bags, which is available with a next day delivery directly from us. Please PM me a delivery address and we'll sort it out for you this time. Also we'll be arranging for a larger stock @Plasterers1StopShop shortly.
