15mm plasterboard .
Heavier to use, but if the wall is out of level, 15mm are really good for straightening - they don't twist easy.
15mm boards are lovely to stick as long as they have been stored correctly ie flat. I suppose its a slightly better job but be aware that door linings and window boards may need to deeper than usual.
I fit screws to wall so the heads are all lined up level. Use straight edge. Line. Bubble Level. Screw in / out to get it correct then dot and dab to screw heads.. Works for me.. Just a bit of messing setting up
I take it you've never dot and dabbed on price
Not really. Used to do bathrooms and the walls had to be spot on for tiling. Private jobs. I used to use 12.5mm board and used the screw trick. Also works on over boarding to level out,plus I dot and dab to pack gap between ceiling and board.
Here's one ceiling I had to level out. I had to get it spot on.. Then skim..
15mm plasterboard .
Would bonding not do the job ?
Tuff one to level out with bonding I thought, plus bad cracks going right across. One joist moved when stood on from above to so I packed out with plastic packers on wall edge. Right job to sort! Done a few over the years though.
