6mm beads yes or no?
ankers
Having to go over someone else's work with 6mm beads. I was going to use 10mm beads but k rend spec 6mm beads and the builder wants to do it in 6mm. Bit nervous about this. Anyone done it before?
They must mean using a poly base and TC finish. Surely not mono on mono at 6mm. Like Dan says. Wrong.
Parex will say 6mm min thickness for over render if the builders been a tight ass it’s a nice easy job in one pass if it goes tits up you’re only doing what he asked
