No bro dont use a brush that will look f c in awful.
You just trowel it in and rub it up with the trowel float lile you would normally. Thats the only way.
your background is true plumb and square - the texture is a 1.5mm coating thick - it would be impossible to lose the sharpness with a coating of only 1.5mm it follows your backing.
