victoriadl
Hi,
I hope you can help me!
Within the last 2 - 4 weeks I've had GTEC plaster cove fitted and as of yesterday I can see that it's splitting / shrinking at the joints. We've told our builder and he has responded with the following: ''..hairline cracks are common in newly plastered areas, which are prone to shrink and are very sensitive to movement. Houses will move with the climate, heat and moisture which will make them expand, cold and dryness will make them contract. It only takes the slightest bit of movement for cracks to appear'.
I'd be grateful if plasterers can advise as to whether I should expect the coving to behave in this manner and whether I ought to expect this shrinkage at all? Plus what in your opinion will likely cause the coving to shrink and split at the joins as mine has done?
I've attached images of the 4 areas of coving for perusal.
Many thanks,
Victoria
Many thanks,
Victoria
