airless plastering??
Albertsclacton
i suppose this one is pointed at currier....,i might be wrong...but he is the airless whore lol!
will a graco rtx1500 spray multi??,on veiwing it has a built in compressor,massive hopper...
says it sprays plaster/render but is this mp gear and acrylic render :/...at £3000 bags,got to be good if does spray,seen on youtube puuting some heavy texture through it..and 230v
worth a nose
just a bit of burb
The RTX 1500 is packed with innovative features and performance points – designed for the professional texture contractor.
Features:
  • RotoFlex HD Texture Pump*
    • 2.0 gpm (7.5 Lpm) output gets the job done quickly
    • 100 psi (7 bar) material pressure allows longer hose lengths, minimizing time spent moving the sprayer
    • Large, 7/8-in ID pump tube passes large particles easily
  • Automatic Pressure Unloader*
    • Ensures a soft start with each trigger pull
    • Eliminates the material blast that can impact finish quality
    • Results in less material waste and less clean up
    • Dramatically extends pump life
  • QuikChange Pump Section
    • No-tools pump removal and replacement
    • Changes in less than 5 minutes
  • High-Output Air Compressor
    • Produces 6.5 cfm @ 45 psi
    • Projects texture farther
    • Maximum 10.2 cfm displacement for long life
  • Larger-Capacity Hopper
    • 15-gallon capacity
    • Steep sided to keep the thickest muds flowing to the pump
    • No-tools removal for easy clean up
Specifications:
  • Max Working Pressure: 100 psi (7.0 bar)
  • Max Delivery Rating: 2.0 gpm (7.5 Lpm)
  • Motor Size: 2.0 hp
  • Weight: 124 lbs (56 kg)
  • Compressor Air Output: 10.2 displacement cfm,
    6.5 cfm @ 45 psi (.18 m³/min)
not knocking a eze 24,never used one...and cant comment
Price: £3,599.00 ex VAT..
price of the eze 24,i suppose you would need a compressor with this??
£1000+....ex vat
just curious as the graco looks the part at a fraction?
and thats not a knock to eze
Your looking at £5000 inc mate for the eze24 with compressor and training plus a great back up service
Hmm or 7500 ish for a ritmo think thats making my mind up more ...... I thought all in would be about 4000 ish max ..... Lol
Are you sure the rtx1500 is airless cos i've never seen an airless gun with an air line going to it before. Think i would be asking Graco if it would spray gypsum successfully. cos if it wont and you don't ask i think you might be learning how to dismantle one and re-build it rather sharpish :)
worth a nose
I don't think it will spray skim just watched a video of the rtx spraying. It would be to slow and it would clog
Looks like a s**t screw pump to me. Would not want to spray anything gypsum based with that. Graco mark V and hopper with bag roller for airless
