I knew you.d had a bad day.Wetting up a wall on 2nd trowel!!!
I'm f**k*d if I know how to make that work yer freak!!!!
Ha I wasn't the only one to give it a go today thenWetting up a wall on 2nd trowel!!!
How I play but with brush not spray bottleMy old best method was two coats, flatten, two wet steel trowels with spray bottle and then final/cross dry plaz or super flex. Used to dry out really good but past two years nearly every way I try very inconsistent results.
If your using flex the same as mt.....you've no hope lol
I'm f**k*d if I know how that works!!!
Spat dummy out and told 1 of lads to finish troweling up and went and sulked outside and start beading render up on scaffold!
Phhhhhhh F*****g skimmers!!!!
Mate that @algeeman is f**k**g dog rough so don't try to be like him, he doesn't even scrim down his beads! Oh shite, no that's me isn't it, err well me and him are both rough, don't be like us.I'm f**k*d if I know how that works!!!
Your heads programmed into a certain way of skimming you've been at it that long.
I was the same.
As mad as it sounds you need to let the flex trowel do the work mate.
I've shown loads of lads on site only a hand full picked it up with a bit of patience
I dunno wtf to do with them bloody flexis things!
Last month's rage was not needing any water and now yer telling me to F*****g wet trowel wet plaster!
Thought my head was guna explode today yer c**t!!!!
Anyway 3 trowels with a MT next time im skimming!
I'm guna render section to sulk!
IMHO the flexi's can be used just fine, like the spats, but your timings have to be completely different. Get over the gear way earlier and they don't leave ripples or waves.I dunno wtf to do with them bloody flexis things!
So after ye second coat flatten with water then wet your trowel . Then cross it with flex . Then wet it again.
Do any two people on here skim same way
NoAnyone else do this?
Put it on with mt
Wet gear up n lay in same mix
Flatten immediately with speedskim or plazi
Leave it for bit. Flatten with mt. Wet cross mt
Put it on with mt
I do . Well tickle wall with brush. Found a brush that must of cost 50p . Lad says it's not his but its f**k**g awsome . Soft as f**kYou shouldn't need water if your 2 coating mate
Put it on with mt
its the st gobain syndrome pal or in other words shite materialMy old best method was two coats, flatten, two wet steel trowels with spray bottle and then final/cross dry plaz or super flex. Used to dry out really good but past two years nearly every way I try very inconsistent results.
Or just dance ye cares awayI've gone through every tool and every method a thousand times mate.
Best way is to ignore what your doing and pray for early retirment.
Should of come with me Sunday. Even had aldi's finest coffee . Taste great for first brew then like s**t For rest of dayIl tell yer summet andy inbetween trowels we used to fix beads, load bags out, scrim, fetch water, pva etc etc etc.
Now there's only soft c**t here still doing it as other lads with me just keep touching walls a hundred times with these F*****g bendy things!
Swear I'm guna murder someone at work soon!
im afraid suppliers are making a hard job fcking harderI've been switched sites to push on a Taylor whimpey job.
Supposed to be taped... again.
Dabbed a week ago.
That much fuucking dab on front of boards it's horrondeus.
It just crubbles away in my hands.
Everything seems brittle as fuuck.
Plastering not complicated. Weirdos make it complicated. Keep it simple. No need for fancy trowels if your a good plaster you can use anythingWetting up a wall on 2nd trowel!!!
Bet you cant use a rakePlastering not complicated. Weirdos make it complicated. Keep it simple. No need for fancy trowels if your a good plaster you can use anything
Or a cheese graterBet you cant use a rake
I stay away from my phone at work now.
Days go to shiit staring at porn and William hill.
