Hi All,
I've been reading through some very interesting and informative posts on here and I feel some of them may have already answered my question, but I'm going to ask anyway
I recently moved house and to cut a very long story short the builders pulled a fast one which ended up with me accepting a very uneven garden. With money being tight at the time of moving coupled with an eagerness to learn I set out levelling the garden and building a small retaining wall (circa 800mm high) at the rear of the garden. The wall was a blockwork wall laid on 200mm x 400mm foundations and I managed this without any issues at all. Next step was to render the wall so off I went and bought a series of corner beads and Webber Pral M in white. Not being used to plastering I applied approximately a 15mm base coat of render (I fixed some 15mm lats to the wall and then shuttered the render on, then removed the lats and filled the gap) - I know this isn't the perfect way of doing it, but for me it has given me a decent result but I do have some unevenness. I bought a scratch float and videos online show people scratching to remove any uneven lumps and bumps but when I tried (after a couple of days) the wall was solid and wouldn't budge (even snapping teeth off the float).
I'm wanting to apply a finishing coat to smooth the wall - I can key the wall and apply a top coat, but where am I going wrong. Is my mix too thick which is causing the issues with scratching or am I waiting too long? How long would you expect to wait from applying to scratching (on say a 10 degree dry day).
I watch tutorials like this one () and I should be capable of giving a half decent finish on a garden wall.
Thanks in advance for any help.
Regards
Phil
Regards
Phil
