timmo72 said:doing a chimney brest tmrw averaged size gonna put angle bead on the corners pva it all skim the front and the 2 sides should take no longer than the morning ... so wot would u guys charge for this
timmo72 said:do u use one of those edging trowels big mart if your doing all 3 sides in 1 hit ???
TrowelADDICT said:id charge £458.24 ;D
fordon said:Priced a similar job a few weeks ago and got it at £150 Inc mats.
timmo72 said:days wage .. plus materials .... cheers lads ... nearly at the 250 big mart i see
fordon said:Was a very large breast!!! ;D
fordon said:Your house
fordon said:F**k corner trowels,i keep it tight and paint them in, works a treat every time.
timmo72 said:must be good working wi someone in the know .... i usually do it in 2 hits the front the the 2 sides but tmrw will do it in 1 hit . get home early sounds good for a friday
timmo72 said:im gonna do it lads .. in a oner . will keep ya posted 8)
BARFLY said:I'd get a second man in to feed you - you dont want the mix going off before you get it all on. he can help you trowel up as well.
BARFLY said:it's called irony, mate
