Any advise to stop a guy knocking himself out on his stairs?
Lostgeordie
Hi guys,
This place looks great place for plasters to discuss ideas/problems.
I am not a plasterer but do have a plastering issue which is causing me a headache.
We have a new loft extension which we are thrilled with. But it's came to box in the stairs and the builder have found plaster boarding it very difficult. This is the best they could do.
The problem is its created a real pinch point and means I can't really walk up and down the stairs holding the banister.
There seems to be an alternative on here - using a mesh to create a much tighter curve.
And if it come in behind the post we would maximise our headroom.
So my questions:
- What do I need to ask for?
- The builder says his plaster had no more ideas. Do I need to find a new one?
- Any good places for sourcing someone. I'd rather stop this getting plastered and be 100% we've done everything because it's such a shame for us.
Sorry if this is inappropriate place to ask.
We live in whitley bay, North tyneside, ne26 1tf.
regulations are there needs to.be a certian minimum height.. but cant remember what the height is..
you can batten the batck of stairs in a fan like form. following the runner line against the walls
mesh the battens and rockwall beforhand aswell.
tight coat of bonding to form the curve then skim
2metre head height from the tread below. By the looks of it it’s the newel post which is the lowest point. Not a lot you can do. Roll the winder round with eml as dan says. Take it you couldn’t of had a dropped landing before the first winder. Must be to regs or it won’t get passed off.
Hi guys,
So my questions:
View attachment 26084View attachment 26085View attachment 26086View attachment 26087
Way around it would of been the have the bottom winder dressed. Then it wouldn’t of needed plastering at all. Stairs would of been a few quid more.
Hi guys,
So my questions:
You're wrong.. This is a great place for fights, name-calling and popcorn. Sometimes crisps. Good luck
Hi guys,
So my questions:
A curved winder can be achieved by a couple of techniques. baton, felt or builder paper then EML. (Chicken wire)
bonding coat to form the curve then plaster
Personally I bed a bit of fibreglass mesh through sections that have heavy footfall, probably not necessary but belts and braces and all that. You could fix lats to eliminate curvature, then mesh/bond/skim
The end result should be a nice sweeping curve with no sharp edges
You my friend are class!
