aqua board
Drew_Palmer
Need to get some 'aqua board' for a shower thats being put in. It's gonna be tiled. One piece will be screwed onto battons, the other will need to be stuck to the existing wall. *How do you stick it to the wall? Can you use normal board adhesive?*Do you need to use special tape for the joints?*Can you skim over the board?if you can, do you need to prep the surface with pva or just spread straight onto the board?Anything else i shud be aware of when using it?Cheers fellas.
Dont skim on it just tile over it, im not sure about adhesive though i dont see why you cant though, i used it in my bathroom good boards but very expensive
