a guide to applying textured coatings ;D ;D
A textured coating will level up uneven surfaces and cover cracks up to around 3mm (1/8in) wide - the coating is flexible, unlike normal paint, and reduces the possibility of cracks reopening. Textured coatings can be used to provide a number of different finishes which, if required, can be painted in a colour of your choice.
As with all decoration, proper surface preparation is vital. Wallpaper (including painted wallpaper) must be removed and the surfaces thoroughly cleaned (in particular, getting rid of grease and nicotine stains). Sound paint can be left in place, but all loose and flaking paint (and all distemper) must be removed before you start. Remove any tiles from a ceiling along with their adhesive.
Porous surfaces should be treated with special sealer and cracks larger than 3mm (1/8in) should be filled with wall filler: a special caulking tool is available to make this job easier. Filled cracks and joints between new plasterboard should be taped over with joint tape (tape should also be used on the edges of filled areas). If any parts of the wall are powdery or 'chalky', use a stabilising solution before applying the coating.
Mix up powder, following the manufacturer's instructions. To speed up this process, whisk attachments are available for both hand and powered drills. Ready-mixed products can be applied straight from the tub. Use masking tape to protect electrical fittings, timber paintwork and exposed plumbing pipes. Lay a dustsheet on the floor.
Textured coatings can be applied with a large paint brush (wall brush) or roller. The application method is different to paint as the coating is applied more or less in one go rather then being 'worked' once it is on the surface. Apply the coating to the wall or ceiling in bands around 60cm (2ft) wide; if you are applying a pattern, do this before applying the next band of coating.
A brush or roller will leave a relatively flat surface (its texture depending on the type of coating being used), but if you want to provide a decorative pattern, this is done once the coating is on the wall. There are several different texturing tools you can use to provide the pattern:
* patterned rollers for producing diamond, diagonal, bark and stipple patterns.
* brushes and stipplers for creating a wide range of textured effects.
combs for creating artistic combed textures (including flower and rose designs as well as standard linear ones).
* lacers (triangular plastic hand-held blades) for smoothing tips of heavier random textures (broken leather, bark and swirls, for example) to reduce the sharpness of the peaks; a standard set includes medium and small sizes. The tool is kept damp with water and is used before the texture has gone firm.
* margin brush for creating borders around textured patterns and also for painting around fittings.
* You could also use a damp sponge to create a stipple effect or your own swirl design.
Edit: this is a copy and paste
