Evening folks
I have had a look over the forum to see if i could get an answer for my question but have not been able to find it.
Hopefully you dont mind me using this mine of knowledge that is around here.
Ok
We have an extension onto an old stone built house
Construction of walls is
1.Stone wall
2.4inch cavity
3.75mm celotex
4.thermalite blocks
kitchen is on the ground floor and a bedroom above
have decided to go with the batten and board option (mainly because of access probs)
am using 25 x 50mm roofing battens
now what i was wondering is if it is ok to add more celotex in between these battens and then board.
Am I right in thinking that because of the cavity we wont have any condensation issues if there is no gap between the 25mm celotex and the plasterboard.
Cheers all
Any advice will be greatly appreciated
Ok
1.Stone wall
2.4inch cavity
3.75mm celotex
4.thermalite blocks
Cheers all
