Bauwer light
Vincey
Anyone ran it through the Ritmo not mix and pour got a couple of jobs with it and ideally would like the machine to mix it as one is 80 mm spec
You need the modified mixing shaft for the Ritmo. Pft northern have them about sure about the other dealers
80mm? :eek:
You don’t need modified shaft Vincey. Ritmo won’t work in Siberia anyway
Thanks @TheWand i ring them found this yesterday
Checked with client @vfr apparently 65 mm is ok on spec gives approx 0.55 u value
It does look slow tbf but great that it will go through
I have done 70mm. 40mm 1st day 30mm second day. Hand applied. But the Ritmo maybe same day 2 passes.
Thanks mate appreciate that , I finding it hard to work out a price on job tbh as not got a clue how long to gauge it will take , tbh might be better on a good day rate
