S a plastering
got a sectional pebble dashed garage we want to krend tc15 what's the best base coat for this going to take a bit to cover this also what stage of play would we mesh it thanks
Cheers mate what after that hp12 or carry on with uf baseid blind it out with hpx..if.needs thickness id go standard uf.
cheers can you sponge the uf up same as hp12 matecarry on mate... hp is good aswell if u dont wanna use uf.. either or mate
don't know anywhere that stocks that mateEnewalls MPA is decent gear for building out
what base coat mate by wetherby?just get down to Wetherby. Dub out heavy bits first. Then a good heavy coat thats meshed. Go back the next day and skim over it and a quick sponge and you’re ready for the Top Cat.
Premium adhesive. Fairly heavily polymered and only £10 a bag. You’ll get about 2m2 a bag on a bad substrate. Doesn’t have the same body as HP12 but will stick better if sticking is what you need.what base coat mate by wetherby?
cheers palPremium adhesive. Fairly heavily polymered and only £10 a bag. You’ll get about 2m2 a bag on a bad substrate. Doesn’t have the same body as HP12 but will stick better if sticking is what you need.
If a lot of dubbing out is needed i’d just micro and OCR. Suppose it all depends on your location to materials etc etc.
