I need to replace my broken corner trowel so was wondering which one is favoured? Personally I've always struggled to find a good one but cannot really mange anymore without one, thanks
Refina do canny twitchers
Premium Quality Stainless Steel Corner & Angle Trowels For Plasterers
The one at the bottom........................:RpS_thumbup:
you have to run it up both sides ben and pretty pointless when its soft ,personally I get it neat with trowel only, then on my second trowel I use twitch ,with refina twitch I had to sand edges a bit because there outta shape and dig in a bit , just my opinionI got one of them on your recommendation arti, find it very strange to use what is the process when you use it? I ended up running down both walls to get it something like but felt like it took forever plus it's was digging in a lot..
At what point do you start using it? I used it as per any other twitcher just before I give it a first trowel..
Using ox now too,instead of mt, better valueOver the years weve tried em all stood on em lost em but its ox one for me cheap aswell!
I use one of those cheapy tichy corner trowels off fleabay. Shoved a stick in the end to make it a bit longer. Works for me.
is the stick not on so you can chuck it further
Is the mattress still on itmines made from the corner of an old bed-frame steel, welded to a handle. no movement. Astm is mine.
