bit of a problem
S a plastering
someone else has reborded a ensuite ceiling thats 20mm out at one end and its been fully tiled so it shows up they want it level so was thinkin of bonding straight away but for quickness would putting strips of 10mm oplasterboard across where it needs it then try and plasterboard an skim what ya think also i have to do this workits for a builder i do a lot of work for its the bathroom fitters who have done the ceiling not knowing itsnot level the bakes cheers
cheers rock will do was gonna put some maskin tape underneath the line round the room aswell so nowt goes on tiles nice job for a monday morn me thinks not ha
its meant to be that way divvy... to chuck the rising condensation (steam) away from people in the shower or bath... DUHHHHHHH
If it's miles out dab some rips of board on the worse area then fire some long enough screws through to the joists and rule of that
do ya mean like the blue insulation tape not quite sure what this blue tape is pal
no mate the blue masking tape doesnt leave any residue.any time im working to tape i always take the tape off before final trowel come off easier and you are still able to repair any tears if any happened when you pulled tape off
