Don’t bother Just use cove adhesive, it trowels up lovely!Hi guys , has anyone ever used bonding coat for skimming ? Looking for any info whether it can be polished up to a good finish ? Multi finish seems o be in a national shortage at the moment . Thanks .
I can't see any reason why a lightweight backing wouldn't trowel up lovelyHi guys , has anyone ever used bonding coat for skimming ? Looking for any info whether it can be polished up to a good finish ? Multi finish seems o be in a national shortage at the moment . Thanks .
If the surface you're going over is a bit rough, then throw a handful of ballast in for the first coat
It's better giving it 3 1st coatsYes mate it will be fine dont listen to this lot there so negative and defeatist at times.
Just treat it like multi and crack on.
Thread closed!
Allways one that goes to farIf the surface you're going over is a bit rough, then throw a handful of ballast in for the first coat
