Bottle cove reskim
Got a ceiling to reskim.Has a tight cove that comes down wall about 4 inches then has a lip of about 15 mm to the wall.Can skim cove fine until it comes to the corners.NIGHTMARE.Any ideas what tools best for tight corners.Leaf and spade? Sponge?small trowel?.Been told to cut plastic lid to form shape and run it out of corners.Plus would you use a stop bead on bottom of cove for crisp finish.Brushed in on the old lip looks abit shitty to me.
Pics for the perverts would be helpful mate.
Rotate a 8" plate in the corners , I've left you one in the kitchen (y)
What
Use a joint rule for the corners
  • Bottle cove reskim
Grind uour skim into the lip skim the ceiling an in the corner cut a radius out of of a credit card an do the corner bit of fanny around buf that's the way it is might be better with 2 of you
Skim the ceiling over the the top profile of the cove. THEN fit new gyproc cove. Job will look s**t hot.
I Thankyou
