Looks like one coat skimming, not a good idea,
Should be 2 coats. PVA it and reskim, scratch it on, lay it down, flatten it, trowel it up,go to the wall 5 times, simple.
Did you do the plastering ?Hi everyone, have a few problems with newly plastered walls, I can see the joints in insulated plasterboard and hair line cracks in places what can be done to fix this any advice would be appreciated View attachment 72063View attachment 72064View attachment 72065
Hi Toby, look on the bright side at least you don’t need glasses to see the joints in the plasterboard so there’s a positive otherwise that plastering is shite and I like the way the boxes have been cut out too.Hi everyone, have a few problems with newly plastered walls, I can see the joints in insulated plasterboard and hair line cracks in places what can be done to fix this any advice would be appreciated View attachment 72063View attachment 72064View attachment 72065
Is that a mirror photo ?
Decorater will catch that.Hi everyone, have a few problems with newly plastered walls, I can see the joints in insulated plasterboard and hair line cracks in places what can be done to fix this any advice would be appreciated View attachment 72063View attachment 72064View attachment 72065
Would that cause the cracks scrim tape was definitely used?Looks like one coat skimming, not a good idea,
No was done by a pro, the builder who got him to do it insured me it was double skimmed, I’m not convinced that’s why I’ve come here for sound adviceDid you do the plastering ?
Bright side ,what’s wrong with the boxesHi Toby, look on the bright side at least you don’t need glasses to see the joints in the plasterboard so there’s a positive otherwise that plastering is shite and I like the way the boxes have been cut out too.
In the old days b4 self adhesive scrim, spreads would put a bed of finish on the joints and stick bandage scrim onto the joints, perhaps the silly p##ck is still doing that method.Would that cause the cracks scrim tape was definitely used?
What’s wrong with the boxes???? Seriousl???Bright side ,what’s wrong with the boxes
No way that was done by a competent plasterer.No was done by a pro, the builder who got him to do it insured me it was double skimmed, I’m not convinced that’s why I’ve come here for sound advice
Yes seriously what is wrong with them?What’s wrong with the boxes???? Seriousl???
Can’t fault his work in other places just this room, no he didn’t board it but surely if he thought it wasn’t boarded correctly he would of said, it was all fixings no bondingNo way that was done by a competent plasterer.
If the same person boarded it then that’s probably the reason it’s hairline cracking, could be a number of reasons incorrectly bonded/tacked etc.
I’ll let the paint fill the cracks so job doneNo danger It’s all right that is, just the glancing light coming through the windows makes it look worse than it is
The crack only starts half way up the wall
Yeah only mechanical fixings, it was 50mm insulated slabs , I think it was 12 to 15 fixings per slabJust mechanical fixings?!!
Who done the boarding?Yeah only mechanical fixings, it was 50mm insulated slabs , I think it was 12 to 15 fixings per slab
symmetry…nuff said.Yes seriously what is wrong with them?
Double scrim bad practiseNo was done by a pro, the builder who got him to do it insured me it was double skimmed, I’m not convinced that’s why I’ve come here for sound advice
It was you stewie!!!!! Come clean.No danger It’s all right that is, just the glancing light coming through the windows makes it look worse than it is
Wasn’t me mucky I don’t use scrim tapeIt was you stewie!!!!! Come clean.
