Can you go over k render with and sand and cement 4 in 1 mix?
EKPPMDOVER
Hi
Can someone help answer my questions?
if k render is applied to a garage and has stared to show the block work,then the customer mentions they would like it sand and cement rendered now, is it possible to SBR the k render then apply a 4 in 1 scratch coat?
Hi
There is stuff you can paint it with to hide the blocks showing through, any pics?
Yes as above, use a equalising paint. Parex do a colour wash or use Jub Revitacolor.
You might be better with Rendagrip or Plastprime x. Then go over that with s&c. 4:1 is too strong.
It's called ghosting,
Can't you just use a transparent sealer, then rain ingress will just run down it, rather than Be absorbed into the render.
just go over it with a bucket coat. Did one the other day over mono that was shocking. Sprayed 1.5m over it . job done
