hi,
I have a problem with a rented property. Basically the cold walls facing the elements keep on suffering from massive mould growth all around the windows and the surrounding walls. This keeps coming back despite treating with anti-mould solutions/primer sealer/anti-condensation paint/anti mould paint etc.
I am told this is all due to condensation, but we have fitted humidistat fans, windows opened, heating on etc.
Have just spent a day and a half bleaching it all again. Main advice has been to put celotex 70mm insulation board on the wall, then baton over it, then put celotex plasterboard over the batons and skim.
I have several questions about the process, so please bear with me...
1. can the celotex be fitted straight on to the old dodgy and probably damp plaster, or do I have to hack off all the plaster - am worried if the latter is true because the wall is jerry-built and there isnt a flat brick in the place, all sorts of gaps and chunks and bumps - would probably have to fill it all in first.
2. Should there be an air gap between the exisiting plater and the celotex
3. should I do as per celotex website and cover whole wall then baton over it, or should I put batons on existing wall and put the celotex between them, then board over the whole lot
4. Do I have to worry about the mortar? the pointing is pretty poor, but I am told it wont matter
5. if the answer to 4 is yes, then do I have to rake it out and replace with lime mortar to let it breathe - read that standard mortar doesnt let it breath and so can cause issues
6. What should I use to seal it where it meets the ceiling
7. Can I get away with just fitting celotex on the walls that cause the problem, or do I have to put round the whole room
8. What percentage likelyhood is there that this expensive process will cure the problem and stop people from having to sit there in the freezing winter with the windows open
9. Is there a just as effective but cheaper alternative
Your reples will be much appreciated, thanks
