Usually two opposing large screws either side of motor case 4-6" from bottom , just unscrew and pop new ones in , never owned a £300 mixer I thought the posh ones were brushless lolMorning all, Anyone changed brushes on a megamixer? Am I better taking it to a tool repair shop or is it straight forward. Thanks for any pointers
I've had mine 15 years now it's still working fine . Definitely get another if it diesI also thought the posh ones had overload protection does the mega ?
Good point, I'll check it has brushes first. I'm going through process of elimination. Switch is fine and power running to motorUsually two opposing large screws either side of motor case 4-6" from bottom , just unscrew and pop new ones in , never owned a £300 mixer I thought the posh ones were brushless lol
I'm sure the quality is higher but related to a £50 one of same power it's not my choice , anyway , does it have overload protection ?I've had mine 15 years now it's still working fine . Definitely get another if it dies
Sometimes brushes can get stuck even with the springs pressing , burnt carbon solidifies with moisture ( not common problem ) just make sure you clean out the housing properly before replacingGood point, I'll check it has brushes first. I'm going through process of elimination. Switch is fine and power running to motor
Don’t think the newer ones are as good as the old ones.I've had mine 15 years now it's still working fine . Definitely get another if it dies
God knows I know I cant kill this f**k*r though and it's done some serious mileageDon’t think the newer ones are as good as the old ones.
I always forget poor people have to fix stuff.Morning all, Anyone changed brushes on a megamixer? Am I better taking it to a tool repair shop or is it straight forward. Thanks for any pointers
Must be a newer one then I think I bought mine in 1992Took it apart to its bare bones, no brushes. Power runs to motor , switch is fine. Just won't turn
should only cost £20 in tool shop.Took it apart to its bare bones, no brushes. Power runs to motor , switch is fine. Just won't turn
It's ok for u that has £20should only cost £20 in tool shop.
saves the headache oli mate
Borrow oli 20 quidshould only cost £20 in tool shop.
Thanks for your input budCan't help you Oli, if it's brushless it's got electo magnets which are switched by a controller circuit , I'm guessing it won't rotate for that reason so unless you can check wires to these your stuffed, doubt if £20 will cover it , good luck
I can help you with a link to an eBay special lolThanks for your input bud
Look on the bright side you made someone's dayjust lost it on a bet
Few months back, some guys working next door chucked a mixer in their skip. Resisited the urge to take it and then curiosity got the better of me.I can help you with a link to an eBay special lol
Send it to refinaMorning all, Anyone changed brushes on a megamixer? Am I better taking it to a tool repair shop or is it straight forward. Thanks for any pointers
Good idea, I've just emailed them. Think I bought it directly from them tooSend it to refina
Shop near us that repairs em. They even said only thing that goes on em are brushes and switchesGood idea, I've just emailed them. Think I bought it directly from them too
Chelston rewinds in Torquay mate, take my power tools there for any repairs. Next to brewers and Brandon tool hire on the woodland estate round the corner from inter line.Morning all, Anyone changed brushes on a megamixer? Am I better taking it to a tool repair shop or is it straight forward. Thanks for any pointers
if you die first it gets new owner.I've had mine 15 years now it's still working fine . Definitely get another if it dies
maybe the machine gives you an electric shock and kills you?God knows I know I cant kill this f**k*r though and it's done some serious mileage
what, take the food from an electricians mouth!Do it yourself it’s very easy not worth paying someone else!
Not really a electrician I would say small plant and tools fitter!what, take the food from an electricians mouth!
