We've got a fair bit of conni to do 1.5 mm I've never used it before only noblow I was going to mix it in a hardwall tub, can you put the drill through it to bring it back also I've been told to put 2 cups of water in per tub is this sound right ?
just leave it in the bucket it comes in add a cup of water and spin up do them all at same time and spread them around the scaff use a small saucepan to load your hawk dont worry about getting the lot out of each bucket you should get 12m2 out of each when done collect them all and scrape them into one then put a bit of tape on the lid so you know its been mixed before when you need to use it again just spin up again with no water
add 1 litre per tub.
use a plastic kitchen measure jug to scoop out your gear, hold your trowel to the wall at 45 degrees and pour the gear against the trowel and the wall then just trowel it on
with a swiss trowel you trowel the stuff straight outa the tub with a square edge and spread it over the swissaroo. dont listen to gibblo with the tape, thats what we were doing last season. this season we dab a bit of gear on the lid and scribble "m" for mixed on the lid. it saves loads on tape:RpS_blink:
Cause I'm a sub by throw them away anyway even if there half full cause I ain't paying for the ******* kit mwoooar Hoor hoooooor ..........not the right attitude really is it
