I have inherited a scratch coated property - the quality of the finish looks good and is ready to be top coated.
However, scrach coat is rendered flush with the corner beads. I have managed to get some 6mm battens to render between and then rule off to get an even surface before feathering/floating - my question is what do I do at the corners/edges?
Do I taper the render towards the corner - this would make it very thin, do I fix a straight edge to the corner leaving 6 mm standing proud in line with my battens or, do I fix another set of corner beads to stand proud?
