Cornerstone insulating render
martinemj
Called in to tradlime in Cheltenham earlier today and was given a sack of Cornerstone insulating render to try....
Material is very light apparently using a preportion of glass and nhl 2
Can apply up to 25mm
You can use a lime finish as top coat..
Just wonder if anyone else used it yet?
martinemj
Had a job to try this cornerstone stuff....insulating render
Been a while since i started post so an update
Hacked off old plaster to 1m from floor ....was stupidly thick so will need 3 coats of render
Really light /perlite ,lime mix
Applied in 2 coats on same day 2x 15mm
Need to apply another render coat on Mon or Tues...to bring it out..
It's quite expensive at 15.50 Inc vat(bag is only 9kg) but on the other hand so is limelite at 25.00
tapit
brimplas1
Just trialed some parex renovating.... Just as good as the tarmac renovating.... Just waiting to see the price....
