CPI General Purpose coverage
Rossi46
As the title. What coverage do you get from the 25kg bags? Worked it out from the technicals and i get it at about 1.5 m2 @ 10mm. Is this about right? Thanks.
Also is this the cheapest bagged Sand and cement available?
I haven't used it but i'm told its similar to K-rend's coverge so about a meter or just under at 15mm and 1.1 -1.3 meters at 10mm depending on the state of the structure you are rendering. There are a few lads who use it on here though i'm sure someone will be able to tell you if that's about right or not soon enough.....
I used it a few years back.a m2 a bag @ 15mm.
It cracked on a few jobs which pissed me off.we then used a different comb scratcher and it was fine.
It has tons of waterproof in also
Would you recommend it Bobby or do you use a better alternative now?
It's dear for what it is, I don't see the point personally, If you want to two coat S/C use site mix, If you want to spray, use ocr/parexal. Internal just use hardwall.
Are you one coating that like ocr ? Or is that 2 coats same as normal s and c ?
