church said:KBs in clochester have silka prouducts on special at the mo that tells you somthing ......
pwi said:we dont have plastering sand in this area all we got is building/soft sand ive had a few probs like this recently really (french word)in me off go to such a real effort making it theres yer answer you cant render with building sand periodright then next day the fu**er cracks .and i two coat reveals andy got to be two
[/quthats your answer wrong sandote]
simplybesty said:pwi, are you in wales, we did some work in wales and went to the merchants to get some sand and they looked at me like i was from mars when i asked for washed pit plastering sand, all they had and supply was building soft sand. If you have a real problem mate, use OCR from euromix CPI about 3.50 a bag all ready to go, just add water...
im in south scotland simply this ocr can it be used for any purpose .i was the same i moved here 4 years ago from brum and went to the merchents and asked for plast sand they hadnt a clue ?? ???
essexandy said:What's your local sharp sand like pwi? In some areas the sharp is fine enough to use and this will be clean, I did one with some not long ago.
sharpe sand here is like concrete sand abit course .theres a travis perkins a few miles up the road ill give them a ring see if they can get me som plast sant
this could also be down to differential shrinkage cause when your top coat is stronger that your bottom coat, what was your mix ?
