Crazing!!
aspire
Hi.
can I ask a question related to crazing .
should I be using SBR between coats of render or would a damping down have prevented the crazing if the top coat.?
Thanks in advance
Welcome aspire, can't see the need for sbr on a scratch. If your topcoat is pulling in too fast then wet down or use a little water proofer in scratch. Read up on old threads here, some useful stuff
Hose the scratch down until the water is running down the wall then leave it till the shine goes off it and its good to go. No need for sbr
I had my first ever wall craze ,,sbr with cement,,while still tacky applied pricking up coat ,slight shrinkage ,scratch coated 2 days later ,no shrinkage ,left a few days then top coated ,it crazed
Hi.
Thanks in advance
Crazing in your top coat may not always be down to your suction on your scratch mate, theres loads of factors to consider, Crap sand, incorrect additives, wrong ratios on your mixes, time left between scratch and top, top coat also needs to be kept hydrated whilst and after its been done.
the best sand I could find was blended ,however im new to Cotswolds ,in cornwall we knock up at 4 to 1 ,that's normally both coats with lime in top coat
Your mix should get weaker with every coat and thinner.
For example. Scratch coat of 4:1 sand and cement at 10mm
Float coat of 5:1:1 sand cement lime at 8mm
Hope this helps.
Good morning.
Ive been using sharp sand from wickes/b&q would you suggest using this or should I be using something else?
You can get plastering sand from b and q , the sharp has to many stones in it from what i remember i used 2 sharp 2 plastering on sum dampproofing very stoney thou would not like to rub up a finished face using it as i was skimming it was fine though !
