You need to put secondary fixings in them, on corners/reveals cut out the foam on the edge of one so the other slots in so there's no foam on show
Do you mean fixings additional to the adhesive?
thanks for all replies.
Thanks, I've used similar to fit warm roof decks. How many do you use per board?
Depends who's boards you are using some spec 3 straight down middle others 4, 1 in each corner ish.
Cheers mate, last question do you drill them in or just hammer them?
Props off the seal/floor , nice off cut of timber to suit sat on props.
