Dabbing
jamesthefirst
What do you use to hit your boards with?
I need to get something new to replace mine which I’ve found to be a bit light.
don't do enough of it to comment but when called for short 4x2 and if needed a rubber mallet and check with 6ft level
Use feather edge to tap. You can see if it’s straight at the same time. Tap all boards then go over with level and adjust if needed
Vagina my arse... Ste V en
Like V for Viagra...what makes you a goddamn sexual Tyrannosuarus.
RARRRR look out Johnathen.
We've got some narrow aluminium rules that are light as f**k. I foamed one end then once it had set I filled the rule with dry sand and foamed the other end. Nice rule now.
Foam .....ye animal. I.ve got same might do it to mine lol
