A mate of mine has just bought a solid stone cottage. The survey highlighted a small amount of damp on the external walls.
The house has had a chemical damp course installed, but the guarantee for which has nearly expired.
The current walls have been plastered with an artex plaster. He wants the job doing right and i happy to rip the lot off and give the room a re-vamp.
I would like you guys to give me some advice about what options i have now, and more importantly the financial implications each system would have.
Option 1- hack off all original plaster, put in new chemical damp course, plaster back with limelite plaster (done this before-but only up to 1.2m high) Limelite plaster is never cheap, and the stone walls will be all over, so...
Option 2- hack off all original plaster, put in new chemical damp course, then throw up a gyp-liner false cavity, insulate, and then maybe board with foil back boards? This would help with the potential re-wiring he may/may not be having.
Any other options you can suggest are welcome, or if you guys know of any websites with a step by step guide showing which products to use etc, that would be great. I have covered some areas involving damp/rising damp in the past working for the old building company, but rarely come across it these days, but would like to do more of it in the future, hence why it is so important this job is done right!
Also, would i be able to use the original damp course holes to inject the new stuff in to?
Many Thanks
Many Thanks
