Dashing on Weber Aid and Plastic beads
KevinHarrison
As the title really..
I’m doing a rendering job,I’ve beaded up with plastic beads and used Weber aid and mesh.
Now the customer wants to know if it can be dashed rather than Weber pral M monocouche.
There having loads of work done and I think things have become tight hence the change in mind.
So my questions are can you dash over the Weber aid and mesh,and can you dash over the plastic beads..
Never done either so any help or advice appreciated
use a thin coat dash receiver the same as if you are working on an EWI system.
Malc, if it’s down to material cost it could end up costing more. Dash receiver isn’t that cheap plus pebbles.
I think you could sand and cement over this. Is it keyed or smooth? If its smooth then you may need to sbr it.
