OldProperty
Hi all,
Our property is a old 1800s stone wall property. On the outside, some of the mortar has been repaired by someone patching it with concrete (not lime and cement which I believe should of been used).
In the inside, the plaster has blown in quite a few places, mostly at the bottom of the walls. Today I took a SDS chissel to the wall to remove some of the plaster to inspect what was going on and to see what the walls consisted of.
I've attached some photos, you can see the original stone and then there appears to be two separate layers of plaster and then a final "skim" of plaster.
We are thinking of taking the walls back to stone (remove the plaster with SDS) and then batten, insulate, plasterboard and then plaster (skim) the walls.
After any advise or suggestions. Does the above sound OK, will the walls be able to breath?
