essexandy
The Lake Governor
As they have been mentioned in a different thread I thought I'd ask some questions.
Most of the off shelf door linings for block walls seem to be 132-135mm (51/4in. in old money), these are the traditional size going right back to the days of render, float and set and allow between
10-13mm more thickness overall (both sides of the wall) than the recommended 22mm for backing coats (S&C, Hardwall etc.) when used with 100mm blocks.
This situation gets even worse when these frames are used on 95-100mm studwork, with up to an extra 8mm of extra Thistle having to be applied.
I've worked on quite a few jobs that have had their frames run up to the correct size but......
How many of you work on jobs where the frames are run to the correct size?
Do you charge more for the extra thickness's? I realise than in the present climate we're all swallowing more and more but what about in normal times.
