Hi all,
Need some urgent advise thanks. I wanted to create a home office so had the outhouse in my garden fitted with 6 double power outlets (back boxes to the brickwork) then dot and dabbed directly to the brick with, on advice of the builder, Knauf 27mm XPS plus insulated plasterboard after applying PVA to the brickwork. The plasterboard was then skimmed.
Bitumen paint was applied to the concrete floor, then self leveling concrete then laminate laid.
Once all was dry, they painted initially with a mist coat of emulsion paint then with Dulux Easycare. This dried then immediately crumbled and flaked. They claimed it was the Easycare being kept in the cold outhouse but believe it or not, this is the least of my worries!
I have noticed that the power outlets get quite a bit of condensation forming on and around them every night which is quite worrying (I have now turned off power to the outhouse at the fusebox).
They assured me when I initially noticed it, that it was the plaster drying but its been weeks since it was plastered and I am still noticing the condensation. I have read a little and suspect the condensation is forming as the warm air is travelling through the plasterboard, hitting the colder brickwork which is forming condensation on the Backboxes as they are attached to the brickwork
Am I on the right track in anyones more experienced opinion, or is it a bigger issue? Most importantly, how do I rectify this?
Its getting colder and I have noticed rust forming on the brand new power outlet screw today!
I just want to make it safe and avoid condensation ruining the whole structure - ideally without having to rip everything down but worse case, I will have to do this. The structure was in place before just as a brick shed and never had condensation issues before.
I currently have a dehumidifier running in the room and was told maybe a condensation sensing vent fitted would help but I am not sure. I have also been told that the power outlets should be surface mounted to the plasterboard. My worry is that the cabling between the outlets are on the brickwork so cable would still have to be presented through the XPS. At this point, I have no idea.
Your advice is welcomed and appreciated. Thanks
is welcomedx
