Linton1990
People have so many different ways of doing things now, it becomes very confusing on what is actually the best way!!. So i thought id see what different ways you would all deal with the following situation.
So the render/plaster in a bathroom is blown and comes away back to the brick. How would you treat a 9" solid external wall, i was taught to sand and cement render the wall, but bathroom fitters don't want to wait 28days for it to dry before they can tile. So normally they would request i dot & dab it with MR board. I was recently questioned about dot & dabbing a solid external wall creating damp between the wall and board. I can only see that this would be a problem if there was damp in the wall to start with. at which point that would need sorting first. How do you all deal with 9" solid walls with no cavity insulation?
