Dot dab
P.S im in kent and need some were can i pick some up round maidstone the neighbours keep hearing us bonk starting to p*ss me off
your only sticking it to the weakest background....
From what I would would do is batton and put more insultaion between the battons
Builders merchants dont know a great deal cos if they did they would be doing it them selves
Danny
ant said:
Can you stick polystyrene back boards with dry wall adesive?
Yes you can mate , then stick a couple of fischer fixings through the board into the substrate to give a mechanical fix in case of fire
You can only stick phenolic boards with adhesive i always thought, BG do a board now thats laminated with celotex and its only for mechanical fixing
they have had them in ireland for a while now... they call them slabs though they get mush room fixed to teh walls
Danny
Danny
i like this..
richardbrown said:
They are a right t.w.a.t to dab cause they are heavy and awkward. cut them with an old saw
and 99% of the time bent to f**k. score the back vertically and horizontally to straighten them out a bit
And no matter how much you sweep up them f*cking balls of styrene still get in the skimming.
Just another box to tick in the I f*ckin hate plastering list :)
