Dot dab
carys
ok lads if tanked walls many times before but iv never dot and dab straight on tanking is this ok ? Or is it going to cause problems later on
they will not show if I tank and then scratch whith sbr ?
Condensation will form on the tanking if the wall is cold room is warm. If you scratch then the moisture is less likely to. Still better off with insulated boards though.
What's the problem with dabbing on wall that have been tanked and a coat of s&c over it??
