Eml
Arti
Not used it for a while so do you lads n lasses ................
1. put freeflo or (waterproofer of your choice) in the pricking up coat
2. In pricking up & Scratch
3. Just in the scratch.
Cheers in advance for all relevant answers.........................:RpS_thumbup:
2-3 wud be fine either way ..... No harm in abit waterproofer in it and u want it in the scratch defo , depends how big it is aswell u might want a bit suction if its small ....
Personally everything outside I generally put waterproofer in. The amount just varies depending on where and which coat.
@Arti never in the prick up coat, any water taken in by the prick up coat will help the scratch coat to cure slower/better.
First name terms again!!
I'm onto you.
Your a right columbo you Stuart .........................:RpS_laugh:
****, ive just called you by your 1st name...................:-0................stone cold busted......................:RpS_crying:
Knew it, who are you really? You know far too much. It only said Greg in marshys sig but you knew his name was Gregory.
Does anyone use S&C for the pricking coat and then top in OCR?.....................can it be done ?
i went over a 2 year old scratch in ocr on my garden walls and it aint fell off yet
probably no help whats so ever :RpS_mellow:
