EWI fixing boards and render rates
RoyCooper
Hi been offered work on external insulation system , basically fix the base bear the the insulation boards then render first coat bed the mesh ,2nd coat leave flat or sponge ready for primer 3rd coat acrylic render he is offering €12 p hour any thoughts after you spit out ya coffee
Lol
If you're in Hungary that's a decent hourly rate then
It's on old houses to upgrade u value it's the complete job not just plastering beads fills etc you get nearly that for the plastering day rate for a plasterer is between 150/210 a day price work varies roughly €4 pm² skimming 7-10 s&c plus skim
then surley you know £12 an hour is shite ...when your gaffa is getting at least £30/40 a metre.
